ENGINE ADVICE PLEASE!!!!
RE: ENGINE ADVICE PLEASE!!!!
just boost your z6 you have in it right now, if you build the block and do eveything right you can push 325 at the wheels which will stomp just about ANYTHING on the road... if you spend the money making a car n/a you will have to replace half the parts, a n/a engine isbetterhigh compression a boosted engine is better withlow compression.
for 4k you can make one hell of a sweet turbo setup, and you can tear into your motor and have it completely built to handle 350 for around 1500 i would say...
take your caps lock off too, you make yourself look obnoxios...
ORIGINAL: blackmassacrer
FOR A GOOD ENGINE ABOUT $500-$1200. IM SURE THAT CAN GET YOU A PRETTY NICE MOTOR HUH
sure, you can get a low milage z6 for around 600, build and boost the hell out of it, and be making serious power that will send a lot of people home crying. Just because a motor is cheap, does not mean i dosent have potential.
