D17 Crower Cams
Old 09-06-2005 | 05:00 PM
Chimera02EX's Avatar
Default D17 Crower Cams
Ok all you knowledgable Honda freaks, heres a good one for you.
Crower makes a camshaft for the D17, well actually 4, my question is...
With running a turbo, which would be my best choice? I understand that the stage 2 is a "boost" cam but I am planning on running 10+ psi. Yes I am bulletproofing my engine and getting a professional tune.
(Stage 1, N/A, Daily Driver, Stock Idle, RPM Range Idle to 7000+)
(Stage 2 Boost Special, RPM Range 1000-7500+, Req. #84116)
(Stage 2 N/A, RPM Range 1000-8000+, Req. #84116)
(Stage 3 N/A, RPM Range 1250-9000+, ECU Mods Req.)
Old 09-07-2005 | 05:38 AM
Default RE: D17 Crower Cams
I know it seems like a no brainer, I should take the stage2 boost special cams, but my thought were higher RMP = more power. And even though stage 3 says n/a would I still be able to use it with FI?
Old 09-07-2005 | 09:06 AM
sacicons's Avatar
no, the turbo needs a different profile than a non-FI. FI doesnt like overlap, and NA loves it. go with the turbo cam.
Old 09-07-2005 | 09:50 AM
Thanks Sac.
DjHagios
07-29-2010 05:38 PM
joshhondacivic
01-31-2008 05:58 PM
evotechnik
09-17-2007 05:36 PM
javierdagreat
09-01-2005 01:01 PM
