d15b7 head swap
RE: d15b7 head swap
yes and yes the d16y8 is a good head to put on your motor because better then a d16z6 head. and also its a v-tec head buuuuuuuut [8D]your gonna have to get a comp or ecu for the v-tec if you dont have v-tec in your car which i think you dont. you can get a ecu from a any civic v-tec or get a APEXI for to control the v-tec. so yeh the y8 head is good i suggest you'll do it your gonna feel the difference with the v-tec good luck with the mini swap.[sm=smiley20.gif]
RE: d15b7 head swap
well i dont really how much bhp you gonna get out of it. it depends on the head you get. heres a site for info on the swap http://crx.honda-perf.org/articles/z6swap/z6swap.html. also you know the is there another thing you can do to the motor to get some hp gain its another mini me swap. the d15b has a dual point fuel injection. you can put a intake manifold from a d16z6 or d16y8 the y8 intake manifold is bigger so i would say go with that and get that head to but the z6 head and manifold also is a good. soo i say all that would get you about 50 more horses? or more not sure never tested yet. the only thing i know is that the d15 motor has more compression so its a good combination. ummm yes your apexi can work very well with the v-tec and the cool thing about that lil comp is that you can make the v-tec kick in at anytime you want unlike getting the ecu which puts it at around 4000-5000 rpms. when you get the mini your gonna to change alot tho i got that site for you but from a what i know your gonna have to change your distrubitor because of the dpfi has to 2 wires i think and the multi has 4. also wiring the v-tec. well anyways if you need anything else just ask
RE: d15b7 head swap
well with the head and the intake manifold it'll be like about 50 depends what you kinda work you do to the head and the manifold i have internal head work done to my y8 head. and the intake manifold is a after market product so about 50 all together you know. but just stock yeh about 25 my bad
