Compression Test
Old 09-05-2007 | 04:49 AM
Default RE: Compression Test
ORIGINAL: Mr Mobsta Man
Wide open throttle, You are supposed to push the petal to the floor while cranking... and I forgot to.
That is correct. I forgot to do it while running my first compression test as well, and we were seeing all kinds of different numbers. I ran the test probably five times, and came up with different results every time.
Once I held the pedal at WOT while cranking, I had perfectly consistent numbers on 3 tests
Skrapdoggydog
01-16-2007 01:14 PM
b8teen
17
12-19-2006 06:17 PM
01CivicEX
08-30-2006 11:05 AM
Meta
08-10-2006 01:46 AM
chones2083
06-02-2005 06:48 PM
Quick Reply: Compression Test
