Charging A/C
Charging A/C
Hello guys,
I got a '95 EX and the A/C is not blowing cold. Just a little colder than when just the fan. I bought a charge kid but I'm not sure exactly where to charge it. The guy at Advanced told me to put it in the valve with the "L" on the plastic cap. I tried this and it did not seem to help much. The pressure went up a small bit but not into the charged zone on the gauge. I could tell no difference in the A/C temp. There is another valve with a plastic cap labeled "H".
Do I need to charge the "H" valve as well?
Does it normally take more than one 12oz can to charge the system?
Thanks
Thanks
RE: Charging A/C
never put it on the high side or as called H always on the L or low side and when you do it run your engine with the blower on high now when i did mine i started doing it and i saw that it was coming out on a high side line and bought a new line and then it worked but you might have a leak check all around on your lines see if you have a leak you prolly do if it is not holding pressure or the freon in there and you might want to try another can i am not sure cause some guy i talked to about it they said it takes about 4 of those cans to fill it all the way up but dont listen to me cause it could be couple of things lol just check for leaks first
RE: Charging A/C
ORIGINAL: kyrupp7
loyolarobyn
11-13-2004 12:54 PM
