A/C Doesn't blow cold air anymore =/
Hey guys.
Well, my a/c used to blow good cold air, and now with the heat I need it more than ever.
So what would cause the a/c to not blow cold air? Only blows hot air.
RE: A/C Doesn't blow cold air anymore =/
Does pushing the A/C button activate the button light? If not, check for blown fuses (#17, 47, 57).
If so, does the condenser fan run and compressor clutch activate when the A/C button is pushed?
Is the A/C compressor belt broken?
r-134 gas is low in it. check the simplest stuff first like the fuses and such. work your way up to the more complicated tasks. sometimes the smallest thing keeps it from working correctly.
Haha, windows thing doesn't necessarily help much when its over 100 degrees outside.
I'm thinking it has to do with the compressor. The a/c light activates, blows hot air in, the condenser fan runs, but I don't see any freon at the site guage flowing.
Edwards329
01-12-2014 10:00 AM
phil946
01-24-2011 03:58 PM
Steve925
06-27-2010 03:21 PM
03civiclxcoupe
03-28-2007 10:44 PM
