building b18a1...need help!!!
I have 99 HB and i want to put in a b18. in my garage i have a b18a1 sitting there w/o a transmission. my neighbor was telling me to build the engine with aftermarket internals but i was more thinking along the line of putting a vtec head on it with a gsr tranny. what's the better idea here, i am going to build the head regardless of which head ill get but i want to keep it NA.
What are your goals for the car? 200hp? 300? thats key. If you want to save money and still have a fast car, I would say screw the build, if its in good shape, just do the ls/vtec with some other mods youll be at 200.
well my goal is to at least be 250, at most 300. money isnt too much of a problem cause im not putting that engine on until somewhere around june or july. its going to be for my little brother who is getting his license soon. obviously i want a relatively reliable engine that wont crap out after an oil change or two. at most i want to spend about 2500 to 3000 and thats including the tranny so really about 1500 2000. would that vtec be a good jump without completely making it unreliable or would it be better to build the ls and just get a simple ls tranny? as you can tell im not to familiar with b series engines lol
Why does a first time driver need 250-300 hp? enjoy the body damage.
for 250-300 your looking into either turbo or nitrous. Which arn't cheap. Either way with those your going to want to build your internals. If you turbo your going to want a ls tranny because of the long gears your going to stay in boost longer. So basically for that goal id say you need ls/vtec turbo. research that.
b18a1 is good for turbo or supercharging, however i would rather just get the vtec head from a b16 or gsr, vtec conversion kit, b16 tranny, p28 ecu with a type r base map to start off and you should have a nice lil setup. your lil bro is lucky for getting a 99 hatch hopefully he takes good care of it...
http://hondaswap.com/hybrid-ed-ef-da...bo-both-23064/
read that read it well the ls/vtec is a ticking timebomb under boost unless done right
what do you mean by "done right"? are you telling me that I cant boost it too much or i can't advanced the timing to much or what?
Forty04
04-11-2007 10:08 AM
syrusstephens
04-14-2005 01:00 AM
