b16b vs b18c5
Old 02-15-2005 | 09:23 PM
Kappa22's Avatar
Default RE: b16b vs b18c5
its got the same stats as the type-r teg motor
...except for the displacement. And actually, it's only 11:1 CR (an almost insignificant difference) and 10 lb/ft more torque. If you can find someone/someplace to do an install who knows their stuff, definitely go for it. $2,500 is a hell of a deal (is that for E/T/ECU?)
  #22
Old 02-15-2005 | 09:29 PM
Roost3r's Avatar
Its got around 30-50k on the motor
• Complete Motor
- Block
- Intake Manifold
- Complete Head
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Ignition Wires
- A/C Compressor
- Power Steering Pump
- Headers
• OBD2 ECU (Computer)
• 5-Speed FWD Hydraulic LSD Transmission
- With Clutch components assembled to the engine
• Intermediate shaft
• Wiring Harness
  #23
Old 02-15-2005 | 09:32 PM
Kappa22's Avatar
Damn, I'd ****** that up. Normally they run around $4,000. But is the engine tested, and does it have any kind of guarantee/warranty?
  #24
Old 02-16-2005 | 03:21 AM
Roost3r's Avatar
compression tested and 60 warrenty..
http://www.jspecautosports.com/catal...spx?prod_id=15
  #25
Old 03-15-2005 | 04:31 PM
copyguy6188's Avatar
go with b18c5, stock i run 13.9 at 107 and with 50 shot nos i run 12.8 at 123. can't do that in ctr.
  #26
Old 03-16-2005 | 01:46 PM
sugerbear008's Avatar
i am still a novice to the engine types the 18c1 is the type r? c5 gsr? 18c=?
kap i can get the f20 for the same price how complicated is the swap?
  #27
Old 03-16-2005 | 08:40 PM
XCM828's Avatar
You got those backwards. c5 is type-r and c1 is gsr.
  #28
Old 03-17-2005 | 12:28 PM
oh shouldn't the type r be better than gsr?
  #29
Old 03-17-2005 | 12:38 PM
Roost3r's Avatar
well for one..the type r motor is like another 3 grand. yes it IS faster stock, but the gsr motor holds up better on mods and is only a little slower then the r motor and alot cheeper
  #30
Old 03-17-2005 | 11:28 PM
sacicons's Avatar
well wait. the type r motor doesnt necessarily not hold up on mods. it just wont take to turbo as well as the slightly lower compression GSR/b18c1. for NA, the type r motor is hard to beat.
Nizzle410
12-14-2006 11:52 PM
SiRacer
01-25-2005 09:22 PM
99ctr
05-28-2004 11:03 AM
