air conditioning
air conditioning
can any one tell me what i need to install air conditioning in my civic dx? the air is not broke. the car came factory with out it. i know adding air will rob me of alittle power, but i also know, being in the heat all day every day will make you wish you had air conditioning
RE: air conditioning
Depending on the model year, you may still be able to buy a complete air conditioning kit from a dealer (one of the discount on-line dealers would save you quite a bit). Or find a parts car and strip all the A/C parts out of it (don't reuse the receiver drier though, buy a new one). Once you have everything bolted on take it to a shop to have the lines evacuated and charged with refrigerant and oil.
ORIGINAL: mk378
Should cost less than $100, you can also buy borrow or rent tools to do it yourself, which will pay for themselves in a relatively few uses.
Lambo, if you have just leaked some out over the years, you can use a gauge manifold (about $80) and a can of R134a to top it up. You don't need the expensive part, the vacuum pump, unless you need to take the system apart. Don't use those really cheap little hoses with a single gauge, you can't tell enough with a single gauge to charge it properly.
apoplectic1
04-18-2010 03:07 PM
1995, 2007, ac, adding, air, civic, complete, conditioning, cost, honda, installing, kit, kits, refrigerant, unit
