1993 running rich
RE: 1993 running rich
the o2 sensor is good . and checked with a known good sensor the reading averages about 1350 millivolts normal should be 450mv the ecu also toggles back and forth in open and closed modes. the fuel pressure controled is 35 psi and uncontroled at 46psi. the car has a new radiator , thermostat, and water pump. runs at 240 degrees at about 65 mph also has an occasional spark knock.
So thats the technical stuff anyone have any clues are these known to crack heads? I will be doing a leakdown and compression test later maybe tomorrow. this has been a really good car 169,000 miles.
Thanks in advance for any help you might be able to provide.
scottdh20
11-24-2007 07:50 PM
