k24 into a civic! noobie at cars
my goal is to get a k24 into a 4th gen. civic hatchback. but there are many things i don't really kno bout this. i read somewhere that it has an electronic throttle, and it will cause a problem. k24 in my opinion, is much stronger and better than the b18's and h22's. 2.4lL and has more torque than the others. a turbo will bring out the full potential of the k24. if u got any input plz tell me.
oh yea, wat about a sentra spec-v engine into a 4th gen. civic hatch? is there any engine mounts out there for this engine?
RE: k24 into a civic! noobie at cars
Im sure you could do the K24 with some modding to the bay. Id take the K20 out of a type R over the K20 though IMO.
Also think the H22 has more potential then the Nissan motor.
The K24 is a TSX engine not a nissan motor.
The K24 offers it's own little things that make it a pain in the *** on top of the crap it takes to get a k20 in our civic's.The K24 offers a "drive by wire" system which pretty much makes all your throttle,brake,and other normal mechanical stuff be operated by electronics(hence the "drive by wire")
Can it be done...yes with a K20A intake manifold,ecu,and wiring harness.But it is highly advised you swap to a K20 head and transmission also.
The K24/K20 hybrid is known for good tq numbers and should set you around 240hp and 200+ tq
