EK Swaps 1996-2000 Civics
final check before ordering
Old 02-12-2005 | 01:57 AM
DenkiEx's Avatar
Default final check before ordering
ok im going to be ordering my b18c swap within the next few days i just wanted to post this and get a final check of what harnesses and such i will need for sure.id rather not get half way done and realise i needed a different harness or mounts,
Old 02-12-2005 | 01:29 PM
sacicons's Avatar
Default RE: final check before ordering
if its JDM, it is easier to get a USDM (LHD) harness and change it out, but it can be done with the RHD one, trust me. but it takes a bit of figuring and stretching.
Old 02-12-2005 | 07:31 PM
DenkiEx's Avatar
im almost positive its not jdm its b18c1 american GSR
Old 02-13-2005 | 12:40 AM
sacicons's Avatar
what year is your car, and what year is the motor? also, i put a new water pump and T-belt, along with an exedy stage 1 clutch and a lightened flywheel on mine while it was sitting on the shop floor. i highly recommend that. it will save A LOT of work down the road.
Old 02-13-2005 | 12:41 AM
DenkiEx's Avatar
mine is a 96 civic ex, and i think the engine going in is a 97
Old 02-13-2005 | 01:02 AM
DenkiEx's Avatar
http://www.passwordjdm.com/product.a...For=&PT_ID=134 actualy here this would make it easier for ya this is the swap
Old 02-13-2005 | 01:05 AM
sacicons's Avatar
should be a pretty simple swap then. good luck! and enjoy that beast!
Kappa22's Avatar
Damn, GSR swap with the LSD... you lucky bastard...
Old 02-13-2005 | 01:10 AM
DenkiEx's Avatar
i asked once before about the wiring still not sure as to what im in for can you give me some heads up on the work ill need to do, you mentioned a wiring harness from a 99-00 si??
Old 02-13-2005 | 01:14 AM
sacicons's Avatar
nice, though the GSR LSD is a 2-way. i like the 1.5 for auto-x. but any LSD is better than none. oh, and i think those are JDM, so you may have to stretch those wires a little. theyll fit, you just have to get all of the slack you can.
Quick Reply: final check before ordering
