d16 dead, time to go DOHC, which swap?
okay guys ill say this first and foremost, i searched and couldnt find any great info on what im looking for some im gonna ask you guys, sorry if i could have found it by searching but i tried and didnt.
the d16 died on me recently, got bad rod knock and ive decided to go DOHC. I dont have much money but here there are afew things i must retain, my AC and my PS, oh and cruise control.
i was told a b16 doesnt need any other parts to make the AC and PS work on a formerly SOHC car but a b18 requires a different AC component.
also ive been looking around www.hmotorsonline.com because alot of my friends got motors from them and have had nothing but great results and better service. Is there anywhere else as good as them that might be selling 99-2000 SI motors?
should i go b16 or b18, and if so which one, remember im on a budget but i wanna get the right motor first, i might boost it later also, but thats a maybe.
Thanks ALOT guys you are the best, fo sho.
Huh? B16's love them some boost; they have a lower power ceiling than, say, a GSR engine, but the B16's power ceiling is still well above what you can put down while still getting traction.
Personally, I'd go with a GSR (USDM B18C1) over a B16 (the one in the Si is the B16a2).
But another option to consider would be swapping in another D16y8 and prepping it for boost. You can usually pick up a running D-series for $300-$500 from someone that's swapped it out. A cam would be around $800 if you get new valves and springs. Its 9.6:1 CR isn't bad for boost unless you're running a lot of pressure, so you really wouldn't need to build the bottom end unless you're shooting for more than ~250whp. Then you'll still have money left over to put towards a turbo setup compared to what you'd have spend on a B-series.
I'm not saying you should go for a SOHC (obviously you want a DOHC), but I figured I'd present the other side of the argument
so b18c1? its gonna be awhile till i go boost will this thing still pack plenty of punch? and i think i will ditch the PS BUT im not losing my ac, 125 degree summers, no thank you. What will i need with the b18 GSR motor to run AC? and will the complete swap from hmotors have everything i need or what else will i need to buy (btw im looking at complete changeovers not the motor trans ecu ones)
i gotta get the money now is the thing.
Thanks for the help people.
^del Sol VTEC A/C Bracket (del sol that came with B16)
But this shouldn't be any different than a 99-00 Si A/C Bracket...
Just like the D-series del Sol A/C brackets are the the same as D-series Civic A/C brackets, depending on the engine. The only engine that came in a del Sol that didn't come in any Civic was the 94-95 B16A3. All other engines for del sol were D16Z6 (93-95 Si), D15B7 (93-95 S), D16Y7 (96-97 S), D16Y8 (96-97 Si), and B16A2 (96-97 del Sol VTEC). All of those engines also came in Civics. So I don't know why your friend would mention it having to be from a del Sol.
where would i find the 2 mounts needed and the ac bracket?
