EK Swaps 1996-2000 Civics
b18c5
Old 10-01-2006 | 02:39 PM
thebadgator87's Avatar
Default b18c5
where is the best place to buy a b18c5??? and how much am i lookin to spend??? thanks
Old 10-01-2006 | 04:27 PM
HARI.'s Avatar
Old 10-01-2006 | 10:08 PM
Default RE: b18c5
does that have everything i need for a complete swap??? if not what do i need? and which one would be best for a 99 civic ex
Old 10-01-2006 | 10:18 PM
SpanishFly21's Avatar
Default RE: b18c5
it basically comes wit jus about everything except 2 mount brackets u need the driver side engine barcket and a 99-00 si rear tranny bracket..hari can probably hook u up wit some used parts!
Old 10-02-2006 | 05:19 PM
POLYTHING's Avatar
Default RE: b18c5
cool! how about a B18 or B16 for 2000 ex?
Old 10-02-2006 | 06:01 PM
Default RE: b18c5
it depends...if u wanna turbo out ur car with a b18..u should go wit a b18c1(gsr)..not a b18c5(type-r). type r has high compression..u will probably get more wit a gsr swap!...the same thing for u poly...its a b series. u gotta get a complete change over.
Old 10-02-2006 | 09:43 PM
HARI.'s Avatar
Default RE: b18c5
ORIGINAL: SpanishFly21
good job my friend...sharing what you've learned[sm=rockinit.gif]
Old 10-02-2006 | 11:40 PM
Default RE: b18c5
HARI F****IN ROCKS!!!!!!!!!!!!!!!!!
Old 10-03-2006 | 01:44 AM
Marty's Avatar
Default RE: b18c5
I knew a guy with a built B18C(type r) and was boosted making sick *** power. You get certain things with the C5 you would have to pay alot of money to get done to the C1. A hand assembled head to exact specs that flows great and has nice bump sticks in it stock, also the Type R block itself is braced internaly better than the other B18's to cope with a 7500 to 9000rpm power range needed because it is a race inspired engine. The B16B also has this
Old 10-03-2006 | 02:01 PM
Default RE: b18c5
u see i learn new things everyday..i didnt know that marty..thanx! so u sayin with the right $ u can make a type-r into a beast?
