EG Swaps 1992-1995 Civics
info on Engine Swap!!!
Old 05-25-2006 | 01:24 AM
Iraq Lee's Avatar
Default info on Engine Swap!!!
I just did a major transplant on my car from a d series engine to my JDM B16a engine swap... At first I though this would of been a very hard process but then some one told me about this web site where u can buy preety much anyhonda engine u want based on how deep ur pockets are... So for under 2500 I ordered my B16 that came with everything it needed to run including a tranny... The engine got to the shop in about a week, and few days after that I was driving my civic with a B16 with about 35,000 miles on it all for about 3 grand...
ok so if anyone is planning an engine swap u should check this site out
http://hmotorsonline.com/shop/sc2000...USDM%20Engines
Old 05-25-2006 | 10:20 AM
riceburner700's Avatar
Default RE: info on Engine Swap!!!
thats a really good website
Old 05-29-2006 | 06:55 PM
mprivetts's Avatar
hey did u have to do any wiring. i have heard so much garbage like u goyya do this and cut this here and its stupied.so u done this its just take the old motor out with the wiring harness and put the new motor in with the new harness.
Old 05-29-2006 | 06:59 PM
mprivetts's Avatar
give me the low done on the jdm swap info man please set it straight
Old 06-02-2006 | 08:34 PM
jdmhatch's Avatar
If you get a real jdm motor the the wire harness will not work becuase the jdm motor is for a right hand drive civic and the harness is different so you need to use the old harness and if you have a cx the you need to wire the vtec to the computer
Old 06-02-2006 | 08:59 PM
sacicons's Avatar
ORIGINAL: jdmhatch
you dont "need" to use a USDM harness, its just alot easier and a lot prettier. if you remove the clips that hold the harness in place, it will stretch across the bay to the USDM plugs. but it turns out a lot better looking with a USDM harness wired correctly.
Old 06-02-2006 | 09:17 PM
jdmhatch's Avatar
you cannt use the jdm harness because the fuss box is the the other side. if you do use the jdm harness you will have to run a cable from the starter to the fuss box.
CRLCivic09
EK Swaps
12-17-2006 06:07 PM
bad4yourdaughter
ED-EF Swaps
11-16-2006 05:30 PM
MDmanXP3
09-14-2006 12:04 AM
danielellerton
08-06-2006 09:13 PM
narfman287
EK Swaps
06-24-2006 02:05 AM
Quick Reply: info on Engine Swap!!!
