Brake swap?
Brake swap?
Hi,
This may not be the right forum, but I was wondering about swapping in some better brakes on my 95 dx coupe. Any guides or advice? I'm not up for a huge project, though I have a little mechanical skill and have done simple brake work like replacing rotors and pads. Alternatively, I could pay someone, but I would like an idea of what might be fair labor charges...
thanks
Brad
thanks
Brad
RE: Brake swap?
ok, blank brembo what, rotors? Does rotor type really make a difference? I thought it was more pad and surface area...
here's my level of ignorance- what is a pickle fork? and knuckles? I've read about the integra swap, I assume you mean lower arms or some suspension part that has to be swapped?
thanks
brad
thanks
brad
RE: Brake swap?
yeah, he meant Brembo solid discs (rotors) not drilled or slotted (cheaper than D/S, but good quality), and pad and surface area makes a difference, but a quality rotor is a good investment.
a pickle fork is a ball joint separator(sp?). the knuckles are the front steering knuckles, basically the whole chunk of the front suspension from the upper control arm to the lower control arm that holds the brake assembly. it swaps straight over from an integra or 99-00 civic si with bigger discs.
Ed Fisher
08-20-2009 12:47 PM
Cosworth
12-15-2008 06:35 AM
burgernuds
18
08-16-2008 08:20 PM
j2performance
01-15-2008 02:48 PM
