ED-EF Swaps 1991 and older Civics, CRXs
no spark?
Old 08-13-2006 | 02:47 PM
ls vtec's Avatar
Default no spark?
Hey guys I just put a ls vtec in my crx. For some odd reason the car isnt getting spark!
It runs over but its not starting! I check the cap to see if the rotor is spinning but nothing?
Old 08-14-2006 | 01:32 AM
finalimpact's Avatar
Default RE: no spark?
so your rotor isnt spinning? since you just did a motor swap id go ahead and double check the thermostat ground. if that isnt hooked up you will not have power to the ecu.
Old 08-15-2006 | 05:22 AM
DsR_Ef_ReN's Avatar
i had this problem...u sure its not gettin any spark?..try puttin in a screw driver into the spark wire..and put it like 1 cm away from a negative in the engine like a bolt on the head and see if it sparks..if it sparks then there is spark probaly no fuel..when i did my swap i didn't everything changed distrubutor spark wire plugs...then next thing i find it injectors were clogged..so just check if your gettin fuel in the motor
outlawzz23
04-03-2008 09:56 AM
bulletman0_0
11-09-2004 12:17 AM
civic1.5uk
07-24-2004 04:15 PM
GWhiz
07-03-2004 12:00 PM
buzzro
06-10-2004 01:25 PM
