H22 vs H23 vs F22
RE: H22 vs H23 vs F22
F22A1
belt-driven single overhead cam, 4 valves per cylinder
2156cc (132 cu. in.)
8.8:1
135 bhp @ 5200 rpm
142 lb-ft @ 4000 rpm
readline:????
H23A1
belt-driven dual overhead cams, 4 valves per cylinder
2259cc (138 cu. in.)
9.8:1
160 bhp @ 5800 rpm
156 lb-ft @ 5300 rpm
6500 rpm
H22A1
belt-driven dual overhead cams, 4 valves per cylinder, variable timing and lift
2157cc (132 cu. in.)
10.0:1
190 bhp @ 6800 rpm
158 lb-ft @ 5500 rpm
7500 rpm
300 is not bad at all you should go for it if your really into swaping the f22 in the 4gen. but im pretty sure your going to need after market motor mounts from harasport and someone to wire up the motor to the 4gen also some axles and ecu. could be more.
8.8:1
135 bhp @ 5200 rpm
readline:????
H23A1
9.8:1
160 bhp @ 5800 rpm
6500 rpm
H22A1
10.0:1
190 bhp @ 6800 rpm
7500 rpm
i have the h22 in my 91 civic ex it run low 8s at the track h22 and f22 has far mounts is the same h22 is going to $$$$$ more like said i paid 3,350.00 for complete swap it your call i would not swap a f22 sell save your $$ go for the h22
Low 8's? I call bullchips.
95h22civic
04-22-2008 01:57 AM
