Wrecking yard ecu for 1995 honda civic lx 1.5 I.D.
Hello I was reading the ecu sticky in transmissions and cant seem to determine what my ecu is....as I dont see the numbers it should have although it looks almost identical to the hondata picture. On the outside cover it has a bar code with numbers underneath it. 37820-po6-a02 adn under neath that are 740-741667. The bottom right of the sticker says in caps "AUI". Beneath the numbers it says IPT. I took off the cover and I saw the same 37820-po6-ao2. As far as the resistors go there isnt a resistor soldered into the rp17 spot. I dont see any jumpers to move
