voltage stabilizer and ground wires
Old 04-26-2006, 11:20 PM
outlaw2049's Avatar
Default voltage stabilizer and ground wires
Hey guys, just installed a new stereo system with amp and subs and other electronics. my problem is that now my lights are starting to dimm. my best guess to fix this is to get a volt stabilizer and some ground wires (or if you have any ideas i welcome them) i found this on ebay,
http://cgi.ebay.com/ebaymotors/MUG-G...QQcmdZViewItem
i need to know if they are any good or if i should stay away from them. what wires and stabilizer should i get?
thanx for your help
Old 04-27-2006, 02:39 PM
jwsimons's Avatar
Default RE: voltage stabilizer and ground wires
the thing to do is install a power capacitor, available anywhere they sell stereo's. it kinda acts like having an extra battery
Old 04-27-2006, 03:43 PM
Street Sniper's Avatar
Yeah, get a cap or invest in a high output alternator. You don't have underdrive pulleys do you?
Old 04-27-2006, 04:20 PM
What would the aftermarket underdrive pulleys do?
Old 04-27-2006, 04:28 PM
outlaw2049's Avatar
nope, no pulleys yet. Really what do they do? and how easy is it to istall the capacitator?
Old 04-27-2006, 11:35 PM
another thing are you bridging your subs. when you bridge your subs you draw more amperage which will definetly draw from your altenator making your lights dim.
Old 04-27-2006, 11:38 PM
outlaw2049's Avatar
yep, bridged subs. so how good are the ground cables and voltage stabilizer i mentioned earlier? has anyone taken a look at em? are they gonna help my car at all?
Old 04-28-2006, 12:04 AM
riceburner700's Avatar
i would say install a bigger alternator....
Old 04-28-2006, 02:03 AM
jwsimons's Avatar
that doesnt raely work though because your still dealing with the same voltage regulator.. all around a power cap is the best solution.. as it will also keep those long deep notes from dying.. so they go boooooooooooooooooooooooommmmmmmmmm not just booooo.... and peter out.. want more info go to rockford fosgate forum and read a couple posts..
Old 04-28-2006, 09:40 AM
My suggestion would be either getting a HO Alternator , or getting yours rebuilt at a higher output. IMHO Capacitors are just a "band-aid(tm)" .. They do work however..
HD
Quick Reply: voltage stabilizer and ground wires
