Super D Tuned!!1!
Super D Tuned!!1!
Finally. I should have done this a long time ago.
Just to give you a baseline, I took one of the IC couplers off and did a pull. So basically a stock motor with a turbo in the exhaust stream. = 96Hp. Weak sauce.
Hooked the coupler back up and pulled with the basemap. = 113Hp Even weaker. Basemaps = [sm=smiley21.gif]
Several pulls and lots of tweaking later = Vid
Not bad for a $400 HMT set-up at 6.6 psi.
No longer tuned by G-Tech, but still powered by YooHoo.
RE: Super D Tuned!!1!
I don't understand ? I have d16y8 in my 94si have underdrive pully only running alt. full exhaust,air intake flywheel and a tuned vtec controler and I make more than that to the wheels, 122horse and 110 torque
mentaldis0rder
27
03-12-2006 09:41 AM
