speed sensor bypass???
Old 12-17-2004 | 03:36 PM
col's Avatar
col
Default speed sensor bypass???
Hi guys am fairly new to civics,have a v-tech twin cam with hewland gearbox(ex-honda works)straight cut ,close ratio. The problem is the diff has no speed sensor drive so the v-tech doesn,t work.My question is,is there any way round this ie connect it up to an abs sensor???
The car is used for stage rallying has had the abs system removed and has been quite sucessful.. This gearbox will allow us to get in to 5th on the straights if we can get the v-tech to work.Any sujestions greatfully recieved thanks.
Old 12-17-2004 | 09:01 PM
sacicons's Avatar
Default RE: speed sensor bypass???
is that a dogbox? freaking sweet. if i could have any one part for my car for free, it would be the Quaiffe transaxle. 6-speed, dogtooth, sequential with custom ratios. and a bad *** differential. but i dont have 16 grand.
as for your problem, if you give it a little voltage, it should kick it up high enough to use vtec.
Old 12-19-2004 | 07:41 AM
col's Avatar
col
Its a 5 speed dogbox manual shift The speed sensor has 3 wires going to it. 12v live 5vfrom ecu and earth.so what do you mean bygive it a little voltage.cheers.....
Old 12-19-2004 | 04:00 PM
sacicons's Avatar
find out what the voltage from a speed sensor is, then feed the voltage into it like a speed sensor would. it will give the speedo a steady speed, but it should kick vtec in.
MaximusFunk
07-24-2011 07:53 AM
acadw001
02-26-2008 09:27 AM
civicninja98
10-12-2006 08:08 PM
roudan
01-06-2006 03:43 PM
Auto98EX
10-07-2005 11:54 PM
