SOHC POWER!!??
#33
RE: SOHC POWER!!??
ORIGINAL: d15turbo
with a p28, can i just plug it in n go??
yes, after you get it chipped, and until then you should drive straight to the dyno, becasue all you'll have is a rough basemap and its risky to drive on that.
#35
RE: SOHC POWER!!??
i have to get the ecu dyno tuned for a mini me
#38
RE: SOHC POWER!!??
should i use an aftermarket cam or keep it stock (d16) with the mini me n what other things can i upgrade on the d16 head for the mini me swap. its sucha small swap, so i want to build it up as much as possible minus turbo
#39
RE: SOHC POWER!!??
There's some good D series advice in this thread atm. https://www.hondacivicforum.com/m_320999/tm.htm
#40
RE: SOHC POWER!!??
ORIGINAL: d15turbo
right now i have a p06 i believe...
