Rough starts after fueling or running a/c
Old 08-09-2007 | 09:30 PM
mysi's Avatar
Default Rough starts after fueling or running a/c
I recently purchased an '00 si from an individual and he mentioned due to the MSD ignition, the car runs rough for a few minutes after fueling up. I have recently noticed that also seems to happen when starting after turning off the car while running the air conditioner, but can't say this is always the case. By running rough, I mean the car often takes 5-10 cranks to get it to started and after starting runs at very low RPM (barely staying in a running state) and just chokes/sputters as the RPM gradually increases to a normal idle just under 1000 RPM.
The car has the following relevant fuel system/ignition mods:
MSD SCI ignition
MSD Blaster HVC coil and wires
MSD Dial Rev. Limiter
Venom High Flow Fuel Rail and Injectors
P28 chipped ECU with OBD2 conversion
Any thoughts or clues as to why this might be happening and where I might start to investigate? Thanks!
Old 08-10-2007 | 07:51 PM
phsballer123's Avatar
Default RE: Rough starts after fueling or running a/c
just take it to get scanned they will tell you exactly whats going on
[align=left] [/align]
Mecca8383
03-31-2014 06:15 AM
zrock
09-13-2010 10:33 PM
Sbtflip
24
06-01-2010 01:39 PM
country
06-01-2009 08:01 AM
killasystems
06-10-2006 05:30 PM
