???? p28 from 95 ex
Old 08-20-2006, 02:22 AM
Ej1Rider's Avatar
Default ???? p28 from 95 ex
ok is the p28 ecu on a 95 civic ex automatic... can you reprogram it to work for 5 speed???
Old 08-20-2006, 10:31 AM
Marty's Avatar
Default RE: ???? p28 from 95 ex
yes
Old 08-20-2006, 11:03 AM
Chimera02EX's Avatar
^ does it need to be reprogrammed? Aren't they the same ECU for both auto and manual or do they have different A/F tables?
Old 08-20-2006, 11:21 AM
Marty's Avatar
They are different, dont know how but I do know they are. I am not to much up on what is in a ecu or all that stuff. I know what works and what dont work. Yes it will need to be chipped to change it to a manual from a automatic ecu.
Old 08-20-2006, 04:36 PM
Ej1Rider's Avatar
ok thanks marty, so temporarily can i use the p06 ecu that came in a dx manual tranny, while i go get the p28 from my auto tranny reprogrammed..... i think it will work except my v-tec wouldnt kick in... correct me if im wrong, and one more thing do the honda dealership reprogram ECU's? thanks again
Old 08-21-2006, 02:01 PM
Marty's Avatar
you can have the P06 chipped. No Honda will not touch anything like that.
Old 08-22-2006, 02:14 AM
Ej1Rider's Avatar
ok now i ran into another problem.... my civic that is show on my signature is getting the tranny converted to 5 speed which got the p28 ecu, i probably just get it reprogrammed.... but the problem is my other civic, i looked at my other civic ( theyre both 95 ex .... ej1 ) and the ecu has been replaced with a p06 dx ecu, is it gonna hurt it????
oh yeah and marty, if i reprogrammed the p06... how am i reprogramming it? like should i reprogram it like a p28??
Old 08-22-2006, 09:21 AM
StifflersMom's Avatar
Cat Fuсker
P06 is a non-vtec ecu...can be chipped to be just like the p28...so if it is chipped you might have a p28 equivalent there
Old 08-23-2006, 03:48 PM
finalimpact's Avatar
actually you dont have to chip to convert to manual..........http://www.pgmfi.org/twiki/bin/view/...egraAutoManual my po6 had the same thing done without touching anything but r18/r17......worked like a charm.
Old 08-23-2006, 10:13 PM
Ej1Rider's Avatar
[8D] finalimpact... you are a god !!!!!! but another question...i have another civic ex that have an auto tranny that got a p06 and its not running right.... can that be it too???
Quick Reply: ???? p28 from 95 ex
