opensource logger
opensource logger
i have a 2005 civic and i'm looking for some 'good' opensource obdII laptop software. i have made a 'jeff interface' which is the optocoupler interface. the interface works and i have found a couple of pieces of software that work. i can read and clear codes, get some data but not all. the data that's being gotten also seems to be off just a bit. for example the mph is off by 2 mph. the o2 sensor voltage also seems high @ .660v - .700v which is indicating a rich condition but no code is being thrown and my mpg is still good @ 36.5 mpg.
what i'm looking to get from software is the IPW and correct o2 sensor voltage for tuning purposes. i'd like to lean things out some more.
if anyone has any ideas of another, inexpensive way, to do this...please pass the info on or if you know of another 'free' (opensource) software, for linux or windows, please pass that info on.
tia
tia
RE: opensource logger
ORIGINAL: trustdestruction
obd2 can't be chipped/tuned, you need to convert to obd1 and get a chipped obd1 ecu
what i want to do is make changes to sensors such as the o2, MAP & IAT to lean the mixture of fuel/air. i need a baseline to know where i'm @ and than make changes and be able to see the effects. no ecu changes whatsoever.
I don't see how you're going to lean the A/F ratio without tuning the ECU or without using an FMU.
But yea, idk of any laptop monitoring software.
ORIGINAL: jack987
...the data that"s being gotten also seems to be off just a bit. for example the mph is off by 2 mph. the o2 sensor voltage also seems high @ .660v - .700v which is indicating a rich condition but no code is being thrown and my mpg is still good @ 36.5 mpg.
2) I understand that 0.45V is the voltage indicating the ideal A/F ratio and that 0.66-0.7V is on the rich end. Nevertheless, are the latter voltages necessarily outside of the acceptable voltage range that would throw a CEL code? In this regard, take a look at the wide range of O2 sensor voltages that plot at the ideal A/F ratio in the diagram below (taken from a Civic service manual).
3) If 0.66-0.7V happens actually to indicate a somewhat rich A/F ratio, how do you know that the O2 sensor isn"t at fault?
Edit: Also, if the O2 sensor voltage is really an indication of running rich, why do you think that the ECU is not compensating for this condition?
