OBDO Tuning?
Old 12-10-2008 | 12:08 PM
XNXIXTXRXOX's Avatar
Default OBDO Tuning?
I have a 1st gen B16A I am planning to run a mild turbo set up on. Now my question is how do i go about taking care of the engine managment? Hondata is made for obd1 as well as other so do i have to swap my ecu or is there tuning for odb0?
Thanks guys.
Old 12-10-2008 | 12:25 PM
You have to convert to OBD1.
Old 12-10-2008 | 02:34 PM
croninc's Avatar
Old 12-10-2008 | 02:35 PM
It can be more complicated than that sometimes.
OP: do you have MPFI or DPFI?
Old 12-11-2008 | 05:03 AM
I have MPFI.
Old 12-11-2008 | 05:09 AM
If i were to instead do a mild n/a build 9say stage 2 cams and head build), could i just get a piggy back system/ chip for the i believe pr3 ecu? or is there no way around an obd0 ecu?
Old 12-11-2008 | 09:45 AM
I think all you'll have to do is ECU conversion harness then and the OBD1 ECU for it (P28 I think?). Since you need to buy an ECU I recommend buying a chipped ECU since in the future you'll need a chipped one anyway.
You could probably piggyback but it's not worth it. They're expensive and they suck compared to a chipped ECU/tune.
tac-it&drop-it
ED-EF Swaps
06-26-2013 01:52 PM
mattastic31632
09-26-2008 05:51 PM
1.3mazda
07-22-2007 02:35 AM
bad4yourdaughter
ED-EF Swaps
09-03-2006 01:21 PM
