Knock sensor
Knock sensor
I have a 95 CX hatch. I've owned it from 92,000km to 275,000km and it's now starting an intermitent knock. I did a search in this section and found five posts that contain knock sensor, so I am assuming that the Civic does have one of these. It does not seem that a faulty knock sensor is the likely problem since no has posted with this problem. Does anyone have any ideas? I'm going to do a search on how to check ECU codes and I'll review my Haines manual tonight.
RE: Knock sensor
If it needs premium, it might have some carbon buildup on the combustion chamber. To fix this, i think there is some stuff u spray into the throttle that will eat the carbon away. Don't know much about the stuff.
RE: Knock sensor
Are you throwing a code?
Have you tried premium (higher octane) fuel? Older motors just need premium somtimes.
Only OBD-2 Civics have a knock sensor.
how long do you let your car warm up, and does it go away after it you drive it for a while
Thanks for all the suggestons.
RE: Knock sensor
Well I got the wife to try a tank of premium and the spark knock has gone away. But why does it only knock when the engine's cold. It seems to be totally opposite to what I would think would happen. From what I understand, spark knock is the air fuel mixture igniting before the piston reaches top dead center. This could be caused by carbon deposits in the combustion chamber glowing red and preigniting the fuel mixture or the timing being too far advanced. What doesn't make sense is why does it happen when the engine is cold but disappears when it warms up.
Anyone have any ideas?
I'm going to borrow my dad's timing light and check the timing.
RE: Knock sensor
i dunno if i would pour water into a modern engine. it might not like it. but your right, it usually will knock when its hott, going up a hill under a load.
but if higher octane fixes the problem, then it is spark knock. do you have the right heat range of plugs?
