Injector circuit?? Help
Ok guys first time being on this forum. Its very nice. Lets see if someone can help me..
This is what i have.
89 civic 4-door d15b2 DPFI
For some reason the primary injector.(one on the bottom) isnt getting any power. The top one isnt either but i figured they are on the same circuit. is there a relay or something that would control the injectors.
What i dont understand is that it was just running the other night. Any help would be great.
thanks guys.
thanks guys.
RE: Injector circuit?? Help
Man, I don't know much about the DPFI except that you need to do a multi-point conversion. I do know that you havea small resistor box to your injectors that could be the culprit. Check for continuity through it. Are all of your fuses good?
Yea man i checked all the fuses they are all good. And i know i need to do the conversion. But i dont know where there going to get the ground from. I guess i need to triple check the grounds and make sure they are all good.
Crazeycoop
05-14-2008 05:36 PM
b16Ek4
06-20-2005 10:59 PM
