i need help about ecu!!
Old 01-21-2009, 05:49 PM
Kelley99's Avatar
so i will take a picture my engine and i will attach here... and if i can where is the ecu, i will take picture it too... i hope, we can find what is the problem...
thank you very much as yet..
Old 01-21-2009, 05:52 PM
ECU is under the carpet on the passenger side by your right foot area
we need a picture of the sticker on the end of it that has letters and numbers
Old 01-21-2009, 05:55 PM
The ECU is not so much under carpet as it is behind the front passenger kick panel (below and right of the glove box).
Nonetheless, I really doubt there is any ECU incompatibility given the lack of a CEL code. For example, a D16Y8 has a knock sensor, while the D16Y7 does not. This difference would throw a code.
Old 01-21-2009, 09:11 PM
StifflersMom's Avatar
Cat Fuсker
Ron, that's not entirely true. If he's running a D16Y8 with a Y7 ECU it doesn't matter that the Y8 has a mic attached :-D The ECU won't recognize it.
OP, look up the code of the engine (it's on the timing belt cover and is also stamped on the block) if the engine is a d16y8 than the code on the ecu should be a p2p (I believe). It it's a p2e than it's the wrong ecu for a y8. If the engine is a d16y7 than a p2e is correct...there are other possibilities, but we should start with the engine code/ecu code first.
Old 01-21-2009, 09:52 PM
Gene, I see your point for the said specific example. Thanks for the clarification. For my education, though, what are the key differences between the Y7 and Y8 engines that make their ECUs incompatible yet not throw a CEL?
Old 01-21-2009, 09:56 PM
Kelley99's Avatar
hops..
i tried to find ecu but i couldn't find...
is it in under the yellow cross?? cause it is hard to open for me..but i can do it and it is not my cars picture
Old 01-21-2009, 10:01 PM
okay so did no one notice that i pointed out the same thing like 3 hours ago?
anyway
ron, the differences are that the Y8 is basically a Y7 with VTEC parts in it. The Y7 ECU doesn't see the VTEC parts in a Y8 because it's made for a non-vtec engine so it doesn't care, and then everything else appears normal. The only thing is that it won't engage VTEC.
Old 01-21-2009, 10:02 PM
Originally Posted by Kelley99
hops..
yea that's where it is for me
Old 01-21-2009, 10:13 PM
Trust and Gene, thanks. I acknowledge your examples of Y7/Y8 incompatibilities that would not throw a CEL. Yet, could any of the differences (mentioned or not) account for the poor gas mileage reported by the OP?
Old 01-21-2009, 10:14 PM
it shouldn't be getting bad gas mileage
Quick Reply: i need help about ecu!!
