help with ecu, is this any good
Hi, i have been looking for a while now at ecu setups for my car. i have a conversion harness from obd2 to obd1 on its way, and needa ecuis this any good?? im going t3/t4 on a b16 bout 9 psi. i have also got 440 rc injectors coming, tell me what you think to this this, i found it through a link on the forum! thanks
http://www.xenocron.com/catalog/chip...ecu-p-129.html
RE: help with ecu, is this any good
xenocron hasn't failed yet, to my knowledge..
EDIT: Please keep related topics in the same thread. No need to create a new thread everytime you have a new question about the same part..
do they work as they say with most brands i.e. hondata crome neptune. and how come hondata is three times the price?? the tuner i have chosen uses crome will this be quite compatible? sorry if sounds a bit daft. much appriciated
You've got a lot of research to do... Crome, Neptune, Hondata are not ecu "brands," they're tuning softwares
the ecu you have linked above will work for what your tuner needs to do. Just tell xenocron as much info about your setup as possible, and that you'll be tuning with crome so that they can build you a good basemap
wicked696
06-15-2010 10:16 PM
jax00civic
07-22-2006 04:51 PM
