GSR and 00Si
![Default](https://www.hondacivicforum.com/forum/images/icons/icon1.gif)
can the gsr engine wire harness work with the si engine. I need a harness for my engine.
http://cgi.ebay.com/ebaymotors/OBD2-...spagenameZWDVW
Hey Marty take a look at this one and tell if it could work...
http://cgi.ebay.com/ws/eBayISAPI.dll....cWAT.m240.lVI
The Civics use a one-piece harness that goes all the way through the firewall to the ECU, there is a rubber grommet on the harness that seals the hole in the firewall. Integras use a two=piece harness that connects to three separate plugs on the strut tower. If you were to buy an Integra harness, it would not reach the ECU. You need a 99-00 harness, if you can't get your hands on a Si harness, go with a 99-00 EX 5-speed harness instead. You will still have to modify a few things.
djmatix
10-13-2005 10:19 PM
