GReddy ECU - Any good?
The GReddy eManage programmable engine management unit allows sport compact enthusiasts to tune their performance setup to its maximum potential. Properly tune your factory fuel system your factory ECU and sensors. The GReddy eManage "piggy-back" engine management unit can adjust air/fuel ratios by altering the duty-cycle of factory fuel injectorGReddy E-Manage Control Unit
s by intercepting and altering airflow or MAP sensor signals. Honda tuners with VTEC cars can use the eManage to adjust their VTEC shift points as well.
The GReddy eManage has tons of functionality built-in but inaccessible without the use of a programmer. Additional features include a 16x16 airflow adjustment map, larger main injector correction adjustment, upgrade air flow meter adjustment, boost limiter cut, anti-engine stall, VTEC-fuel adjustment, real-time map trace, real-time display, real-time communication and basic Data-logging.
Sport Compact tuners can use a Windows PC computer based programming setup with the GReddy "eManage Support Tool" communication software to access these additional features. But if you want on-the-fly, in-vehicle tuning capabilities, the GReddy eManage E-01 Programmer <product.asp?prodid=2245&catid=23> is the way to go. The eManage E-01 Programmer <product.asp?prodid=2245&catid=23> comes with a fully integrated LCD screen with navigation system. Tuners can access all functionality of the eManage and store their favorite setups into presets to be retrieved when the time is right. How powerful is that?
Adding performance increasing parts to our sport compacts is what we all crave. Each one of those mods affects the next. Tune your setup as a whole, use the GReddy eManage to do it!
**All installation and tuning should only be conducted by a trained technician with proper air/fuel monitoring tools. (Some functions may not be compatible with some applications)
Kayril
04-23-2014 05:31 AM
Fiasco
01-13-2007 10:23 AM
