fuel filter problem...
Hey guys, I wanted to change my fuel filter the other day and well I ran into a problem. There are two lines: One: runs from the fuel filter to the fuel rail. The second: on the bottomfrom fuel filter to the fuel tank. I took off thetop fuel line, and I started to work ondisconnecting the bottom... but the bolt on the bottom is stripped. There are two places to put wrenches and plythe fuel filter and line appart, but now I cant because only one wrench fits. Is there any way I could grip or get the bottom piece (the fuel line itself) tostay put while I turn the fuel filter off? And if the the bolt breaks in the fuel filter then what? Is there a way to replace the fuel line the runs to the tank?[:@]
RE: fuel filter problem...
If the line wrench does not work , you are going to have to use vise grips you can buy a small rounded pair that should work if you know how to use it, if it breaks , wich it should not, you are going to have to put a new line on it, not hard to do
kenji51590
02-24-2011 05:24 PM
Hailchristian
06-23-2008 12:49 AM
jbarham
04-04-2006 03:05 AM
