ecu question....almost done!
Old 08-15-2006 | 12:40 AM
bobafreaklx's Avatar
Default ecu question....almost done!
hey whats going on? im new to the forum and i had a question. i have a 94 honda civic lx 4 door manual and im swaping a d15b vtec. i already have the wiring harness for it and i was trying to figure what alternatives do i have as far as a ecu. i know the p28 and p08 are the main 2 people go with but im trying to figure out is could i use any other vtec ecu thats obd1 to work with the harness for example like the p07, p27? i also heard the p70 could also work but wont pass the emissions i could careless passing it cause i know a place but im trying to figure out other options besides the 2 common ones. also where could i get the cross over and rev limiter for the examples listed? Also could i use my stock lx ecu to chip to work with vtec besides getting a swaped ecu?
Old 08-15-2006 | 12:51 PM
Default RE: ecu question....almost done!
so im guessing no one knows how to do this either. its not like i didnt search for the information im looking for im just trying to find out how to do this.
Old 08-15-2006 | 07:29 PM
t34me's Avatar
If you know those are the main 2, why not get 1 of them?? Why beat around the bush and make things harder on yourself, just get the right damn ECU. As far as rev limiter, what do you mean where do i get one, its programmed. Bottom line, stop dicking around and just get the ECU you know will work
Old 08-15-2006 | 08:07 PM
Marty's Avatar
Ok here is the deal with the JDM D15B, it has no knock sensor like other obd1 vtec engines. You will throw a CEL with anything other than a P08, also the P28 absolutly kills that engines abilities as it is de-tuned so to speak compared to the P08. I ran my D15B with a P30 which is made for the OBD1 B16A's but once again I had to rig up a knock sensor so not to throw a CEL.
Bar none the best ecu to run the swap with is a P08 or a obd1 ecu chipped with 930 maps and the knock sensor removed.
Marty's Avatar
sorry for the late response also.
Old 08-15-2006 | 11:33 PM
ahh sorry guys yeah i ended up buying a p08 for 65.00 a virgin one. i think my question would be this i heard there needs to be splicing to 3 of the wires to run the vtec. does anyone know of this?
Old 08-16-2006 | 03:20 PM
well turns out i didnt get the right one its a p8!!!! well im going to get the p28. how difficult is that to install besides the p08. i do plan on getting boost soon.
glada96EX
06-29-2006 07:18 AM
MY99SI
05-21-2006 11:24 AM
campbuds
02-05-2006 04:39 PM
INVNO1
01-26-2006 10:23 PM
