Could a chip mess up emissions?
Old 09-28-2007 | 04:29 PM
burnindesirez02's Avatar
Default Could a chip mess up emissions?
SO i have a stock D16z6 with a chip on my ecu... i took it to emissions it failed then took it to an emissions place they said the computer is messed up because my injectors allow too much fuel into my combustion chamber. If i put a 1.8 L fuel map in it will it screw it up? thanks
Old 09-28-2007 | 09:44 PM
blackmetal619's Avatar
Default RE: Could a chip mess up emissions?
yea, it can definately screw it up big time.
like someone already told me, you cant have a 1.8 ecu with a 1.6
Old 09-29-2007 | 05:11 AM
Why would it make much of a difference since i have the stock injectors... Is it that it would just open them longer? Could i just take out the chip and leave everything else on my ecu and it will run like stock? thanks
Old 09-29-2007 | 06:05 AM
if its a chipped p28, you can just cut the jumper that enables the chip, and in theory have your "virgin" p28 again
Old 09-29-2007 | 10:51 AM
I don't think its a p28 maybe a p06 , but i couldn't just take out the chip from it? and do you have a pic of the jumper wire? thanks
Old 09-30-2007 | 06:33 AM
theres pics around here somewhere, do your research. It's the "J1 Jumper"
no, you can't just pull the chip
Old 09-30-2007 | 12:04 PM
I have searched everything i can think of using the search feature and also used Google and Yahoo but couldn't find any pictures of the J1 jumper. Thanks
Old 09-30-2007 | 12:40 PM
Forty, I took mine out and i found two pieces of wire soldered on it... One is at J10, its in the upper left hand side. and another is right above the chip..and a resister along RM11 ? .which one is it? thanks
Old 10-01-2007 | 06:46 AM
It's above the Chip, and says "J1"
take a pic and post it
Sizzlinninja
05-10-2012 05:35 AM
gpacheco101
14
01-24-2007 07:42 AM
CivicEX00
01-08-2007 12:11 AM
needs more salt
07-11-2006 12:34 AM
steven10
04-23-2005 11:32 AM
