converting a po6 to a p28
hey whats up every one i got a couple of questions for you, the first one being i have a 02d011f0-1500 ecu board and i wanted to know if this part list is correct to convert my ecu to vtec;
C60 - 1uf, 35v electrolytic (tantalum?) capacitor
J10 - 0 Ohm jumper wire
Q101 - A143 PNP switching transistor
R201 - 10K resistor (Brown-Black-Orange-Gold)
IC14 - 515 XHigh Side Switch MUST USE 5151's OR EQUIVALENT on this board revision
5050s will throw VTS code.
D11 - Clamping diode
the second question is were could i find these parts at, online or in a store because i have no idea were to look so please help thanks
RE: converting a po6 to a p28
i have no clue if that is what you need, people usually just swap the ecu box alltogether, but as for where to find these parts, check out www.jameco.com, thats where i get all my electronic components, cheep, quick and reliable.
