Cannot read DTC codes
Hello,
I have a 2003 Honda Civic Hybrid and the check engine light is on. I tried getting the codes using a scanner but it did not read anything (it said 'please connect the scanner to car' even though it was already connected). I took it to the Honda dealership and they told me they can't read the codes as well. What could be the problem?
Thanks!
Thanks!
How would you reset the ECU? The thing is I can't read the codes at all, resetting it probably won't help because the codes will come back up (there is a problem with seatbelt and SRS light will come on for sure).
Cutt
02-11-2006 05:38 PM
