Best fuel injector's for N/A B20
The stock honda injectors should be just fine. I have seen over 200 whp on a stock honda fuel system na. Get your tune done and the tuner will be able to see the duty cycle of the injectors. If they are running close to 100% then get some RC 360cc injectors.
what he means is here is his for sale thread you can take a look
https://www.hondacivicforum.com/foru...ad.php?t=78542
they come from a 1991 - 1993 turbo eclipse and will fit on a honda and it is commonly done. and if you need instructions on how to wire them up let me know.
your current fuel injectors are high ohms and these are low ohm thats why it has the resistor box and is easy to wire it up.
DSM injectors fit on hondas with some work. Theres the wiring and resistors plus you need to open up the o-rings. They have been know to leak if not done correctly. 440 or 450cc injectors will be a bit much for an NA setup. Like I said go with some 360cc RC injectors if you need mor fuel. But the stock B series fuel system should be fine.
