Any1 with MSD DIGITAL 7 w/boost retard
RE: Any1 with MSD DIGITAL 7 w/boost retard
Its a b16a, C/R 9.0:1, GT 28R turbo a/r 64, Running 10 psi of boost. Cam gear settings to +2 and -2 degrees. Type R Vtec Camshafts, edelbrock victor X manifold, 68mm holley throttle body..
What other information should I provide..
I know my question is very vague.. but I just wanted to know wat is the Idle tunning that I should do.. Also if any recommendations as to what should my Air Fuel Ratio read... What is the standard Leanreading for a turbo charged b16a..
It sounds to me like you need to bring that car into see someone who konws what they're doing. Runing isn't just something you can pick up and do perfectly overnight.
What engine management are you running?
Get it tuned by a pro, before you blow it up.
