92 civic fuel problem? need help
Old 01-07-2007 | 03:04 PM
armorman2001's Avatar
Default 92 civic fuel problem? need help
[hr]
I got a 92 civic hb with a d15b7 all stock. The car starts and runs great except when you put it in gear. It is an automatic and usually in the morning or the first time riding it throughout the day as soon as you put it in gear it bogs down like it isn't getting no fuel. If you press the gas it doesn't do anything and acts like it wants to die. I have to put it back in park so it can return back to normal idle and then rev it up and slam it into drive just to get it going. After you drive it a couple miles it runs fine and don't have that problem for the rest of the day. I checked the fuel pump and it comes on fine, changed the fuel filter and still does it. I am lost when it comes to fuel systems and would greatly appreciate anybody who may know why it does this. Thanks [/align]
Old 01-07-2007 | 09:06 PM
mugen93's Avatar
Default RE: 92 civic fuel problem? need help
i dont think it is a fuel problem , sounds like a tranny problem i had something like this when my first tranny went bad , but mine was it would move when cold but as soon as it would warm it would just stop and start to idle down like it wanted to die , when it would cool down then it would run ok till it warmed up again, i could be wrong , but that is my .02 cents , hope it help some
Old 01-07-2007 | 09:14 PM
Yeah I hope that is not the issue since I don't have the money to fix a tranny right now. Mine runs great when it is warm but not when cold so hope that is not it. I am going to change my fuel pump, and my fuel pressure regulator and o2 sensor and hope that this will help it. Thanks for your info though I will definitely keep that in mind.
Old 01-08-2007 | 10:18 AM
riceburner700's Avatar
try having a tranny survice done
Old 01-08-2007 | 09:29 PM
mugen93's Avatar
with that year of trann y there is not much servicing to them no filter, and no drain plug[&:], that is why i am on my 3rd one[:@]
Old 01-08-2007 | 09:53 PM
there is a way to flush the system every car has one even sealed trannys
tgrudzin
09-10-2010 02:58 PM
4doorcivic9
07-11-2007 10:54 PM
seriously_furious
08-14-2006 08:49 PM
TheBlackCivic
07-16-2006 11:45 AM
nightrider46
08-23-2005 03:42 PM
Quick Reply: 92 civic fuel problem? need help
