Drivetrain DIYs Anything that involves the performance of the vehicle.
Automatic to Manual Transmission Conversion
Old 05-30-2009, 06:59 PM
WaterCake's Avatar
Originally Posted by rocksbite
i just did this swap. the upper transmission mount is incorrect in the car. the atx mount on the car is higher then the mtx. meaning if you use the stock mtx mount the trans will sit higher on that side and wear out your passenger side axle rather fast.
there are a few after market companys that make the mount but i saw they run about $100
whoah. can i get some opinions on this plz. i wanna make sure to include it in my parts list if this is really true
  #42
Old 05-31-2009, 06:10 AM
oldwhiteprelude's Avatar
its true. i bought a custom mount from ebay for around 70 shipped
  #43
Old 05-31-2009, 09:58 AM
WaterCake's Avatar
what if im planninng to swap the motor and do the conversion at the same time. still need that mount for a b20 tranny?
  #44
Old 06-21-2009, 08:26 PM
ar151666's Avatar
Idk if this is a dead thread and I'll be shot for trespassing but does this apply to a '99 civic too? i need to know if I'll need to buy this "special" mount or not, on JDMUNIVERSE they made it sound like that kind of mount only applies to the 92' - 95' civics...need to know before i start to gather all my crap...
  #45
Old 07-11-2009, 06:32 PM
ronnielee's Avatar
how do cross out the switch for the key to get key out on my 98 honda civic ex im doing auto to manual swap right now need to know so can make work tomorrow some one help me
  #46
Old 07-16-2009, 07:42 PM
WaterCake's Avatar
hey guys i need a quick response plz. will a 95 eg civic's parts fit on my 97 ek for this swapp? its still a d series tranny. if anything i figured id only need dif mountts? will the eg parts work?
  #47
Old 07-17-2009, 02:19 PM
Yes, the EG parts will work just fine.
You need to loop the wire on the connector below the radio (that plugged into the automatic shifter) to disable the neutral safety switch. I want to say you connect the two black 12ga wires together, but I'm not positive; it's been a while since I did an auto/manual swap in an EK. Also, you'll want to wire for the reverse switch, as well as the clutch interlock switch (I believe only disabling the neutral safety switch effectively overrides the clutch interlock, but I'm not positive on that point).
  #48
Old 07-19-2009, 11:23 AM
WaterCake's Avatar
ok where can i get the custom upper transmission mount for my ek. need it within 5 days and the only ones i can find are for eg's. or are they the same thing? i got the tranny with the stock manual transmission mount from the 95 civic, but will i need the custom one to keep my axle from getting worn out too fast?
  #49
Old 07-29-2009, 07:53 PM
WaterCake's Avatar
hey guys! after talkin about it for so long. i finally did the conversion on my 97 dx. its just about flawless. my guy gave me a fair price and did an amazing job. if your in the central florida area and are thinking about this on a budget, i got a guy to do it for you.
  #50
Old 07-29-2009, 07:58 PM
yea its actually not that hard to do i did mine myself and it only costed me 150$
Quick Reply: Automatic to Manual Transmission Conversion
