wire harness
Old 07-12-2007 | 05:19 PM
civicduty96's Avatar
Default RE: wire harness
i'm impressed the big box stores in my town use bell caps, jeff948594 & sigracer10 props to you for soldering. if you dont have time to do it right the first time when are you gonna have time to fix it, i'm just glad to here someone else reliazes the value of doing it right the first time.
Old 07-12-2007 | 06:32 PM
Sigracer10's Avatar
well when im up at work, we use crimp caps, and butt connectors and crap like that cuz it saves a lot of time. but on any car I do for myself, family or friends, I solder EVERYTHING! even the speaker wire onto the speaker. it takes a couple of minutes longer but like you said civicduty96 its the only way to do it right.
Old 07-12-2007 | 08:09 PM
jeff948594's Avatar
those bellcaps suck, i trust the twist and tape method over those damn things.
Old 07-13-2007 | 08:59 AM
my05civic's Avatar
wirecaps are for housing projects; crimp caps are for cars
Old 07-13-2007 | 10:57 AM
jeff948594's Avatar
ORIGINAL: my05civic
im not talking about the twist on things, im talkin about the bellcaps that bestbuy uses where both wires get twisted together, jammed into the bellcap and then it is crimped
http://www.sherco-auto.com/images/CES2214.jpg
that is a bellcap
Old 07-17-2007 | 05:13 PM
cyberx32's Avatar
pretty easy to do like they said, just cut the wires and match the new ones on there. I tried my luck with soldering, but i suck so i just twist and use my trusty electrical tape.
Old 07-17-2007 | 08:00 PM
jeff948594's Avatar
ORIGINAL: cyberx32
twist wires together
put soldeiring iron against bare twisted wire
feed solddier into wire joint starting at soldering iron and work your way up until soldier flows through entire joint
tape
Old 07-17-2007 | 08:18 PM
Sigracer10's Avatar
ORIGINAL: jeff948594
ORIGINAL: cyberx32
tape
well if you have never seen it done and no one has ever showed you, soldering can be kinda hard to master. not near as hardas welding though. (I suck at welding, but i'm good at soldering.) the main thing is just experience. I'm a car audio installer so I have solder maaaannnnnnyyy wires so i'm pretty good now.
xsdudztx
08-14-2007 05:45 PM
Rainingbullets
01-03-2006 07:45 PM
mgm940428
12
12-14-2005 04:46 PM
sugerbear008
03-17-2005 11:31 AM
Quick Reply: wire harness
