vr3 amp
vr3 amp
im borrowing this piece from some kid to see if my old *** jl auido works but when i hook up the remote wire the red light comes on and i have never got to here any spound yet. every thing else is hooked up right but does the blue remote wire hve to be hooked up to work
i dont knoe what the problem is i think its somthing to do with going to my deck cause i bought the car with all the amp wiring in it.
thanks
thanks
RE: vr3 amp
just hook up everything and disconnect the REM line and then take a short piece of wire and connect it from the REM on the amp to the POWER or + or 12V on the amp...whatever urs is labeled as but be sure to disconnect that after u test it or it will leave the amp on al the time even when the car is off and then ur gunna need a new battery...and maybe a new alternator, depending on how long you leave it like that
RE: vr3 amp
i figured it out
the person with the car befor dident have a good enogh ground, i dident trace it bac but i jsut made a new place for it and it worked
and will my amp be always on the way i have it hooked up now form tha batery with tha mosnter wire cable thing
TiaMarie
09-14-2011 09:25 PM
CarlisleP&SPaddy
04-03-2010 06:53 PM
nyce1
06-14-2009 09:42 AM
Bostonhoodhop
05-18-2007 02:13 PM
