tweeter wiring
Old 10-15-2008 | 06:52 PM
burgernuds's Avatar
Default tweeter wiring
hey i just got some tweeters for my triangle but i don't know where to get to the front speakers and which wires to hook my tweeters up to, thanks
Old 10-15-2008 | 08:41 PM
Sigracer10's Avatar
what year is your civic?
Old 10-16-2008 | 08:13 AM
burgernuds's Avatar
lx, ex comes standard with tweeters but a friend gave me ex triangles so i got tweeters but the wiring on them is kind of short thanks
Old 10-16-2008 | 11:39 AM
you might not have the tweeter harness.... the whole harness is different from a model that came with them and one that didnt...
it the plug is not on the door harness then youll have to cut the harness off and simply tie into the harness right next to the speaker.....
Old 10-16-2008 | 11:41 AM
Sigracer10's Avatar
The easiest place to find the wires will be from behind the speakers in the door. you will just tap into these wires for the tweeters so that they run off of the same signal as that speaker. You will probably have to take the door panel off to get to the wire.
the wire colors are as follows
Left front
+ green/black
- light green
Right front
+ green/yellow
- gray red
Old 10-16-2008 | 12:58 PM
also, make sure you're using crossovers to prevent the tweeters from playing frequencies that it isn't designed to play.
Old 10-16-2008 | 03:02 PM
burgernuds's Avatar
seems kinda complicate dfor just two small speakers.
btw do they make any difference?
Old 10-16-2008 | 03:07 PM
they do make the highs sound alittle better and crisp.. usualy the crossover is inline on the harness from the harness plug.
Old 10-16-2008 | 03:11 PM
^Yea as soon as i plugged in my tweeters when i got them, my highs improved so much. Before, my subs were overpowering my highs and I wanted to have better sound quality, but I still wanted bass, so I bought some tweeters and now i can have the best of both worlds.
Old 10-16-2008 | 05:07 PM
burgernuds's Avatar
ya i noticed that whenever i wanted the volume louder, the quality totally sucks
thanks for help.
ian125
10-27-2006 11:35 PM
tripod
09-17-2006 09:33 AM
monge66
12-29-2005 01:31 AM
Element310
05-25-2005 06:08 PM
cnote
04-14-2005 12:32 AM
