A trick I picked up...
Hey everyone, I just wanted to share a little something that I think makes any install in a 99 or 00 civic. When I installed my new head unit I HATED the mounting kits available so what I did was mount the head unit right in there, screwed right to the metal on the sides, then installed a pocket from the bottom slot of a 96-98 civic in below (or above) the unit, it will also mount right to the metal. It looks super clean when it's done and you have a useable pocket instead of a pensil holder. Hope this helps and I'm sure a lot of you know about this but, take it easy on me.
RE: A trick I picked up...
My head unit mounted right to the stock holes in the bracket too. I drilled 2 small holes in the factory pocket and it screwed right in place as well. Saved spending money on crappy "install" kit. Also kept the factory pocket.
ORIGINAL: LEVIII
You can also use the stock 99-00 stock pocket. Mounting it can be tricky but nothing a lil duct tape wont fix
