Too Many Outlets = Dangerous?
Old 06-16-2006 | 05:57 PM
FlipHKD720's Avatar
Default Too Many Outlets = Dangerous?
Would it be dangerous (as in a fire danger) to run a triple outlet such as this one: http://cgi.ebay.com/Brand-New-Triple...QQcmdZViewItem
off of another triple outlet, creating 5 outlets all together? I would do this so i could run 4 neon tubes with DC Power Adapters. Would this create a fire hazard?
Old 06-16-2006 | 08:21 PM
pWnEdU's Avatar
Default RE: Too Many Outlets = Dangerous?
I wouldn't do it... you'll at least be blowing fuses if not burning up wires. Those lights probably have a low enough draw that you won't have a problem, but it just doesn't sit well with me.
Old 06-17-2006 | 11:18 AM
Remmy's Avatar
Its not really a dangerous thing but what will happen is that the gauge wiring and the fuse cant handle to much of a load.
Old 06-17-2006 | 11:36 AM
Pete's Avatar
thats just for ppl who cant figure out how to wire 12 volts.......its so easy.........just do it right.
Old 06-17-2006 | 12:48 PM
FlipHKD720's Avatar
lol i know how to wire a switch and everything, in all honesty im just really lazy...
Old 06-17-2006 | 05:35 PM
jhsplaya08's Avatar
just go to autozone and buy the quad socket adapter from streetglow...or do what i did-cut all the neon tubes and wire 4 into one cigarette plug.
Old 06-17-2006 | 11:26 PM
Method's Avatar
ORIGINAL: jhsplaya08
i tired that and it didn't work, blew the fuse. you up your amperage?
Old 06-18-2006 | 04:10 PM
Remmy's Avatar
^ i rest my case
Old 06-20-2006 | 09:06 AM
Chimera02EX's Avatar
2 words... hard wire. 2 neons per fuse wire it up right to ignition and slap a switch in there, run a 20amp fuse, you should have no problems.
winkosmosis
12-11-2008 11:20 AM
FlipHKD720
10-09-2008 10:51 AM
Storms of War
09-01-2008 12:31 AM
stonerdan
04-15-2006 07:28 PM
