Subs affecting RPM
Subs affecting RPM
After I hooked up my subs and amp and drive around for like 15 min, my RPM drops to about 500 RPM (the car is barely on). hence, my need for a capicitor but I decided to disconnect power cable and now my RPM when in neutral is still lat 500 rpm. has this ever happen to anyone else and how can i fix this?
RE: Subs affecting RPM
Dont know if this relate to it but car battery can possible b the problem. If your running assessories such as subs, neon light, tv etc your might want a better car battery that can handle it.
RE: subs VS rpms
hey bud i have the same problem my rpm guage dances at idle if you crank on it, some amps are just current hogs, while others arn;t so bad. What they have suggested above are good ideas, but if you're worried about just get a beefier battery.
RE: subs VS rpms
I have the same problem with the r.p.m.'s dropping while the car idles. I have an Optima Battery and a 1.0 capacitor.
I'm running a Visonik amp rated at 800 watts RMS( i know its lower) and (2) JL audio 12" subs. Do I need 2.0 capacitor ?
