sounds system drain power from my alternator?
RE: sounds system drain power from my alternator?
you ask this like it is bad... well yes, your sound system does "drain" power from your alternator, just like your power windows, locks, lights, heater, fuel pump, etc. Your alternator generates all the power that your car uses when its running, unless you have a really big woofer and amp, that pull more than the alternator can generate, then it pulls from the batter as well. If your car is not even on, then it just pulls from the battery. So... yeah... this crap is true...
You can upgrade your bat bro, just look around..
http://www.sonicelectronix.com/item_...k+HC+1400.html
Best honda upgrade car audio battery I know of, right there. Or role with an Optima for about 50 less and do some minor mod's to make it fit.
That battery will keep you rolling with little worry of bottoming out your power system. Just don't jam for 3 hours with the car off, you won't be going anywhere.
danomatic93
10-11-2009 07:19 AM
dave_57204
02-05-2008 08:14 AM
Bifur_Eq
10-23-2006 09:53 PM
grunge
09-24-2006 09:00 PM
