soldering help
#21
RE: soldering help
UGH. Don't pay any attention to anything in this thread other than this post, I do this thousands of time for a high-tech bio-med company, I'll show you the light.
1) Strip wires.
2) Tin soldering iron tip... put a small glob of solder straight onto the tip of the iron, wipe off on a wet sponge.
3) Tin wires... one wire at a time heat the end of the wire (quickly)and stick the solder between the iron and wire until the solder flows into the whole wire and coats it evenly.
4) Rewipe the iron tip on the wet sponge
5) Repeat step 3 with the other wire
6) Repeat step 4 (get the idea here?.. after each time you get solder on the tip wipe it back off)
7) Secure one wire then heat up the end, melting the solder, then stick the other wire on it and they'll melt together. Now, remover the iron and blow on the wires, they'll be perminantly attached but if you need to get them apart just apply heat.
That's the way the professionals do it so that's how I'd suggest doing it.
1) Strip wires.
#22
RE: soldering help
ORIGINAL: amg6975
1) Strip wires.
1) Strip wires.
poorb0i
01-05-2009 09:31 AM
